- Joomla 1.5
- Installation
- Mon HTACCESS a-t-il un problème ??
Question Mon HTACCESS a-t-il un problème ??
- jeanmi31
27 Avr 2010 17:38 #1
par jeanmi31
Mon HTACCESS a-t-il un problème ?? a été créé par jeanmi31
Vous trouverez ci-dessous mon HTACCESS et pouvez-vous me dire si vous voyez une erreur car j'ai une erreur 500 :
# @version $Id: htaccess.txt 10492 2008-07-02 06:38:28Z ircmaxell $
# @package Joomla
# @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
# @license www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
#Options +FollowSymLinks
# mod_rewrite in use
RewriteEngine On
############# Use this section if using ONLY Joomla! core SEF
## ALL (RewriteCond) lines in this section are only required if you actually
## have directories named 'content' or 'component' on your server
## If you do not have directories with these names, comment them out.
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteCond %{REQUEST_URI} ^(/component/option,com) [NC,OR] ##optional - see notes##
#RewriteCond %{REQUEST_URI} (/|\.htm|\.php|\.html|/[^.]*)$ [NC]
#RewriteRule ^(content/|component/) index.php
########## Begin - 3rd Party SEF Section
############# Use this section if you are using a 3rd party (Non Joomla! core) SEF extension - e.g. OpenSEF, 404_SEF, 404SEFx, SEF Advance, etc
RewriteRule (.*) index.php
########## End - 3rd Party SEF Section
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to set a mosConfig value through the URL
#RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
#RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
#RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
#RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
#RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
#RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
# Update Your Joomla! Directory (just / for root)
RewriteBase /
#RewriteCond %{REQUEST_URI} !^/index.php
#RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
#RewriteRule (.*) index.php
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Pour faire parser les fichiers ".php" par PHP5
AddType application/x-httpd-php5 .php
#ErrorDocument 500 http://www.votre_domaine.com/500.html
# @package Joomla
RewriteEngine On
RewriteBase /
27 Avr 2010 21:59 #2
Réponse de lavsteph sur le sujet Re:Mon HTACCESS a-t-il un problème ??
je ne connais pas spécialement ton hébergeur, à première vue cela me semble pas trop mal.
Reste qu'il nous faudrait plus d'informations pour t'aider, dont les paramètres de configuration SEF de joomla.
- jeanmi31
27 Avr 2010 22:22 #3
par jeanmi31
Réponse de jeanmi31 sur le sujet Re:Mon HTACCESS a-t-il un problème ??
lavsteph écrit:
Je suis débutant qu'appelez vous les paramères du sef ?? Merci...
27 Avr 2010 22:56 #4
- toutbaigne
- Aimer c'est agir !
05 Mai 2010 17:45 - 05 Mai 2010 18:38 #5
par toutbaigne
Aimer c'est agir: www.amourenaction.net
Réponse de toutbaigne sur le sujet Re:Mon HTACCESS a-t-il un problème ??
Le mien aussi me pose des problèmes...
Il n'accepte pas les accents, dés que je met un accent dans le module de recherche, il m'affiche une erreure 404.
D'ou peu venir le problème?
SetEnv REGISTER_GLOBALS 0
SetEnv ZEND_OPTIMIZER 1
SetEnv MAGIC_QUOTES 1
SetEnv PHP_VER 5
# @package Joomla
# @license http://www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! 1.5 is Free Software
# Ehanced protected filters by Sirius http://www.octeam.fr VERSION DU 2009-05-28
# Support at Joomla Forum http://forum.joomla.fr/showthread.php?t=89166
# Modifications in this file are not part of the original Joomla package !
# PROTECTION FORTE HTACCESS
<Files ~ "^.*\.([Hh][Tt][Aa])">
order allow,deny
deny from all
</Files>
# PROTECTION FICHIERS PAR EXTENSIONS
# AJOUTEZ CELLES QUE VOUS SOUHAITEZ SI BESOIN
<FilesMatch "\.(htaccess|htpasswd|ini|phps|log|sh|.*sql)$">
Order Allow,Deny
Deny from all
</FilesMatch>
# PROTECTION FICHIERS UNIQUE
<Files configuration.php>
deny from all
</Files>
## LIMITE TAILLE UPLOAD POST CONTRE LES ATTAQUES DOS
# PAR DEFAUT A 1MO (1024000 = 1Mo)
# ATTENTION SI ACTIF, PEU GENERER UNE ERREUR 500 SELON VOTRE HEBERGEMENT
#bytes, 0-2147483647(2GB)
#LimitRequestBody 1024000 # 1Mo
# ESSENTIELS
RewriteEngine on
ServerSignature Off
Options All -Indexes
# FILTER REQUEST METHODS
<IfModule mod_rewrite.c>
RewriteCond %{REQUEST_METHOD} ^(HEAD|TRACE|DELETE|TRACK) [NC]
RewriteRule ^(.*)$ - [F,L]
RewriteCond %{QUERY_STRING} ^(.*&)?full_path_to_public_program=http://
RewriteRule ^(.*/)?includes/smarty\.php$ - [F,L]
</IfModule>
# QUERY STRING EXPLOITS
RewriteCond %{QUERY_STRING} \.\.\/ [NC,OR]
RewriteCond %{QUERY_STRING} boot\.ini [NC,OR]
RewriteCond %{QUERY_STRING} tag\= [NC,OR]
RewriteCond %{QUERY_STRING} ftp\: [NC,OR]
RewriteCond %{QUERY_STRING} http\: [NC,OR]
RewriteCond %{QUERY_STRING} https\: [NC,OR]
RewriteCond %{QUERY_STRING} mosConfig [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(\(|\)|<|>|'|"|\?|\*).* [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(%22|%27|%3C|%3D|%3E|%7B|%7C).* [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(%0|%A|%B|%C|%D|%F|127\.0).* [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(globals|encode|localhost|loopback).* [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(select|union|declare|drop).* [NC]
</IfModule>
# CHARACTER STRINGS
<IfModule mod_alias.c>
# BASIC CHARACTERS
#RedirectMatch 403 \,
RedirectMatch 403 \:
RedirectMatch 403 \;
RedirectMatch 403 \=
RedirectMatch 403 \@
RedirectMatch 403 \[
RedirectMatch 403 \]
RedirectMatch 403 \^
RedirectMatch 403 \`
RedirectMatch 403 \{
RedirectMatch 403 \}
RedirectMatch 403 \~
RedirectMatch 403 \"
RedirectMatch 403 \$
RedirectMatch 403 \<
RedirectMatch 403 \>
RedirectMatch 403 \|
RedirectMatch 403 \.\.
RedirectMatch 403 \/\/
RedirectMatch 403 \%0
RedirectMatch 403 \%A
RedirectMatch 403 \%B
RedirectMatch 403 \%C
RedirectMatch 403 \%D
RedirectMatch 403 \%E
RedirectMatch 403 \%F
RedirectMatch 403 \%22
RedirectMatch 403 \%27
RedirectMatch 403 \%28
RedirectMatch 403 \%29
RedirectMatch 403 \%3C
RedirectMatch 403 \%3E
RedirectMatch 403 \%3F
RedirectMatch 403 \%5B
RedirectMatch 403 \%5C
RedirectMatch 403 \%5D
RedirectMatch 403 \%7B
RedirectMatch 403 \%7C
RedirectMatch 403 \%7D
# COMMON PATTERNS
RedirectMatch 404 wp\_
Redirectmatch 403 \_vpi
RedirectMatch 403 \.inc
Redirectmatch 403 xAou6
Redirectmatch 403 db\_name
Redirectmatch 403 select\(
Redirectmatch 403 convert\(
Redirectmatch 403 \/query\/
RedirectMatch 403 ImpEvData
Redirectmatch 403 \.XMLHTTP
Redirectmatch 403 proxydeny
RedirectMatch 403 function\.
Redirectmatch 403 remoteFile
Redirectmatch 403 servername
Redirectmatch 403 \&rptmode\=
Redirectmatch 403 sys\_cpanel
RedirectMatch 403 db\_connect
RedirectMatch 403 doeditconfig
RedirectMatch 403 check\_proxy
Redirectmatch 403 system\_user
Redirectmatch 403 \/\(null\)\/
Redirectmatch 403 clientrequest
Redirectmatch 403 option\_value
RedirectMatch 403 ref\.outcontrol
# SPECIFIC EXPLOITS
RedirectMatch 403 errors\.
#RedirectMatch 403 config\.
RedirectMatch 403 include\.
RedirectMatch 403 display\.
RedirectMatch 403 register\.
Redirectmatch 403 password\.
RedirectMatch 403 maincore\.
RedirectMatch 403 authorize\.
Redirectmatch 403 macromates\.
RedirectMatch 403 head\_auth\.
RedirectMatch 403 submit\_links\.
RedirectMatch 403 change\_action\.
Redirectmatch 403 com\_facileforms\/
RedirectMatch 403 admin\_db\_utilities\.
RedirectMatch 403 admin\.webring\.docs\.
Redirectmatch 403 Table\/Latest\/index\.
</IfModule>
<Files config.php>
deny from all
</Files>
# USER AGENTS
SetEnvIfNoCase User-Agent "libwww" keep_out
SetEnvIfNoCase User-Agent "libwww-perl" keep_out
SetEnvIfNoCase User-Agent "DotBot" keep_out
SetEnvIfNoCase User-Agent "Jakarta Commons" keep_out
SetEnvIfNoCase User-Agent "Y!OASIS/TEST" keep_out
SetEnvIfNoCase User-Agent "MOT-MPx220" keep_out
SetEnvIfNoCase User-Agent "MJ12bot" keep_out
SetEnvIfNoCase User-Agent "Nutch" keep_out
SetEnvIfNoCase User-Agent "cr4nk" keep_out
<Limit GET POST PUT>
Order Allow,Deny
Allow from all
Deny from env=keep_out
</Limit>
################### Ban ##################
############### PAGE INTERDICTION PERSO ###################
ErrorDocument 403 http://www.XXXXX.com/erreures.html
# Only use one of the two SEF sections that follow. Lines that can be uncommented
# (and thus used) have only one #. Lines with two #'s should not be uncommented
# In the section that you don't use, all lines should start with #
# ESSENTIELS
RewriteEngine on
ServerSignature Off
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2}) [OR]
# securite en plus
RewriteCond %{QUERY_STRING} ^.*(;|<|>|'|"|\)|%0A|%0D|%22|%27|%3C|%3E|%00).*(/\*|union|select|insert|cast|set|declare|drop|update|md5|benchmark).* [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(localhost|loopback|127\.0\.0\.1).* [NC,OR]
#RewriteCond %{QUERY_STRING} ^.*\.[A-Za-z0-9].* [NC,OR]
RewriteCond %{QUERY_STRING} ^.*(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC,OR]
# Disable TRACE & TRACK methods
RewriteCond %{REQUEST_METHOD} ^(HEAD|TRACE|DELETE|TRACK) [NC,OR]
RewriteCond %{THE_REQUEST} ^.*(\\r|\\n|%0A|%0D).* [NC,OR]
RewriteCond %{HTTP_REFERER} ^(.*)(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC,OR]
#RewriteCond %{HTTP_COOKIE} ^.*(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC,OR]
# RewriteCond %{REQUEST_URI} ^/(,|;|:|<|>|">|"<|/|\\\.\.\\).{0,9999}.* [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ^$ [OR]
#RewriteCond %{HTTP_USER_AGENT} ^(java|curl|wget).* [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ADSARobot|ah-ha|almaden|aktuelles|Anarchie|amzn_assoc|ASPSeek|ASSORT|ATHENS|Atomz|attach|attache|autoemailspider|BackWeb|Bandit|BatchFTP|bdfetch|big.brother|BlackWidow|bmclient|Boston\ Project|BravoBrian\ SpiderEngine\ MarcoPolo|Bot\ mailto:craftbot@yahoo.com|Buddy|Bullseye|bumblebee|capture|CherryPicker|ChinaClaw|CICC|clipping|Collector|Copier|Crescent|Crescent\ Internet\ ToolPak|Custo|cyberalert|DA$|Deweb|diagem|Digger|Digimarc|DIIbot|DISCo|DISCo\ Pump|DISCoFinder|Download\ Demon|Download\ Wonder|Downloader|Drip|DSurf15a|DTS.Agent|EasyDL|eCatch|ecollector|efp@gmx\.net|Email\ Extractor|EirGrabber|email|EmailCollector|EmailSiphon|EmailWolf|Express\ WebPictures|ExtractorPro|EyeNetIE|FavOrg|fastlwspider|Favorites\ Sweeper|Fetch|FEZhead|FileHound|FlashGet\ WebWasher|FlickBot|fluffy|FrontPage|GalaxyBot|Generic|Getleft|GetRight|GetSmart|GetWeb!|GetWebPage|gigabaz|Girafabot|Go\!Zilla|Go!Zilla|Go-Ahead-Got-It|GornKer|gotit|Grabber|GrabNet|Grafula|Green\ Research|grub-client|Harvest|hhjhj@yahoo|hloader|HMView|HomePageSearch|http\ generic|HTTrack|httpdown|httrack|ia_archiver|IBM_Planetwide|Image\ Stripper|Image\ Sucker|imagefetch|IncyWincy|Indy*Library|Indy\ Library|informant|Ingelin|InterGET|Internet\ Ninja|InternetLinkagent|Internet\ Ninja|InternetSeer\.com|Iria|Irvine|JBH*agent|JetCar|JOC|JOC\ Web\ Spider|JustView|KWebGet|Lachesis|larbin|LeechFTP|LexiBot|lftp|libwww|likse|Link|Link*Sleuth|LINKS\ ARoMATIZED|LinkWalker|LWP|lwp-trivial|Mag-Net|Magnet|Mac\ Finder|Mag-Net|Mass\ Downloader|MCspider|Memo|Microsoft.URL|MIDown\ tool|Mirror|Missigua\ Locator|Mister\ PiX|MMMtoCrawl\/UrlDispatcherLLL|^Mozilla$|Mozilla.*Indy|Mozilla.*NEWT|Mozilla*MSIECrawler|MS\ FrontPage*|MSFrontPage|MSIECrawler|MSProxy|multithreaddb|nationaldirectory|Navroad|NearSite|NetAnts|NetCarta|NetMechanic|netprospector|NetResearchServer|NetSpider|Net\ Vampire|NetZIP|NetZip\ Downloader|NetZippy|NEWT|NICErsPRO|Ninja|NPBot|Octopus|Offline\ Explorer|Offline\ Navigator|OpaL|Openfind|OpenTextSiteCrawler|OrangeBot|PageGrabber|Papa\ Foto|PackRat|pavuk|pcBrowser|PersonaPilot|Ping|PingALink|Pockey|Proxy|psbot|PSurf|puf|Pump|PushSite|QRVA|RealDownload|Reaper|Recorder|ReGet|replacer|RepoMonkey|Robozilla|Rover|RPT-HTTPClient|Rsync|Scooter|SearchExpress|searchhippo|searchterms\.it|Second\ Street\ Research|Seeker|Shai|Siphon|sitecheck|sitecheck.internetseer.com|SiteSnagger|SlySearch|SmartDownload|snagger|Snake|SpaceBison|Spegla|SpiderBot|sproose|SqWorm|Stripper|Sucker|SuperBot|SuperHTTP|Surfbot|SurfWalker|Szukacz|tAkeOut|tarspider|Teleport\ Pro|Templeton|TrueRobot|TV33_Mercator|UIowaCrawler|UtilMind|URLSpiderPro|URL_Spider_Pro|Vacuum|vagabondo|vayala|visibilitygap|VoidEYE|vspider|Web\ Downloader|w3mir|Web\ Data\ Extractor|Web\ Image\ Collector|Web\ Sucker|Wweb|WebAuto|WebBandit|web\.by\.mail|Webclipping|webcollage|webcollector|WebCopier|webcraft@bea|webdevil|webdownloader|Webdup|WebEMailExtrac|WebFetch|WebGo\ IS|WebHook|Webinator|WebLeacher|WEBMASTERS|WebMiner|WebMirror|webmole|WebReaper|WebSauger|Website|Website\ eXtractor|Website\ Quester|WebSnake|Webster|WebStripper|websucker|webvac|webwalk|webweasel|WebWhacker|WebZIP|Wget|Whacker|whizbang|WhosTalking|Widow|WISEbot|WWWOFFLE|x-Tractor|^Xaldon\ WebSpider|WUMPUS|Xenu|XGET|Zeus.*Webster|Zeus [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ^.*(winhttp|clshttp|archiver|loader|harvest|extract|grab|miner).* [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ^.*(libwww-perl|java|curl|wget|python|nikto|scan).* [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ^.*(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC]
#RewriteRule .* - [F,L]
RewriteBase /
#RewriteEngine On
05 Mai 2010 18:40 #6
- Joomla 1.5
- Installation
Temps de génération de la page : 0.205 secondes
