- Joomla 1.5
- installation BDD en locale impossible
Question installation BDD en locale impossible
- meunierpat
16 Sep 2012 21:25 - 16 Sep 2012 23:26 #25
par meunierpat
Réponse de meunierpat sur le sujet installation BDD en locale impossible
Voici mon configuration.php
Si ça peut aider quelqu'un
<?php
class JConfig {
var $offline = '0';
var $editor = 'tinymce';
var $list_limit = '20';
var $helpurl = 'http://help.joomla.fr';
var $debug = '0';
var $debug_lang = '0';
var $sef = '0';
var $sef_rewrite = '0';
var $sef_suffix = '0';
var $feed_limit = '10';
var $feed_email = 'author';
var $secret = 'LRc6qkZjJmkivwhs';
var $gzip = '0';
var $error_reporting = '-1';
var $xmlrpc_server = '0';
var $log_path = '/home/bmsgymna/public_html/joomla/logs';
var $tmp_path = '/home/bmsgymna/public_html/joomla/tmp';
var $live_site = '';
var $force_ssl = '0';
var $offset = '1';
var $caching = '0';
var $cachetime = '15';
var $cache_handler = 'file';
var $memcache_settings = array();
var $ftp_enable = '1';
var $ftp_host = '127.0.0.1';
var $ftp_port = '21';
var $ftp_user = '';
var $ftp_pass = '';
var $ftp_root = '/public_html/joomla';
var $dbtype = 'mysql';
var $host = 'localhost';
var $user = 'bmsgymna_joomla';
var $db = 'bmsgymna_joomla';
var $dbprefix = 'jos_';
var $mailer = 'mail';
var $mailfrom = 'webmaster@bmsgymnastique.fr';
var $fromname = 'BMS Gymnastique';
var $sendmail = '/usr/sbin/sendmail';
var $smtpauth = '0';
var $smtpsecure = 'none';
var $smtpport = '25';
var $smtpuser = '';
var $smtppass = '';
var $smtphost = 'localhost';
var $MetaAuthor = '1';
var $MetaTitle = '1';
var $lifetime = '15';
var $session_handler = 'database';
var $password = 'xxxxxxxxx';
var $sitename = 'Le Blanc Mesnil Sport Gymnastique';
var $MetaDesc = 'BMS Gymnastique - Le Blanc Mesnil';
var $MetaKeys = 'BMS Gymnastique - Le Blanc Mesnil';
var $offline_message = 'Ce site est en maintenance. Merci de revenir ultérieurement.';
- meunierpat
16 Sep 2012 21:36 #26
par meunierpat
Je comprends pas ?
16 Sep 2012 21:46 #27
Réponse de Scottux sur le sujet installation BDD en locale impossible
Tu arrives à accéder à phpmyadmin avec l'utilisateur bmsgymna_joomla ?
C'est normal le même nom pour ta base de données ?
- meunierpat
16 Sep 2012 21:52 #28
par meunierpat
Je ne sais pas comment faire, ça ce complique. Je pense que je ne suis pas assez doué en informatique.
16 Sep 2012 22:20 #29
Tu devrais prendre ton temps pour bien lire le tuto que t'a adressé starter. Il faut bien comprendre les étapes. C'est pas si compliqué mais il ne faut pas brûler les étapes.
Dans le tuto, il est dit qu'il y a un lien sur la page d'accueil du serveur, nommé "Base de données" et qui mène vers phpmyadmin. Ca donne quoi quand tu y vas et que tu essaies de te connecter avec l'identifiant bmsgymna_joomla + ton mot de passe ?
- meunierpat
16 Sep 2012 22:49 - 16 Sep 2012 22:52 #30
par meunierpat
Desolé mais avec serveur2GO ce n'est pas possible de changer quoique ce soit à part la langue, le thème, et la taille du texte
- Joomla 1.5
