- Sécurité Joomla!
- Informations et alertes
- protection du dossier administrator par htaccess et htpasswd
Question protection du dossier administrator par htaccess et htpasswd
- fener
25 Jan 2010 21:29 #13
par fener
Réponse de fener sur le sujet Re:protection du dossier administrator par htaccess et htpasswd
Bonjour.
Donc le mieux c'est utulisé une seul fichier .htaccess
les fichier d'origine dans le repertoire joomla est :
# @version $Id: htaccess.txt 13415 2009-11-03 15:53:25Z ian $
# @package Joomla
# @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
# @license www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
# mod_rewrite in use
RewriteEngine On
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
## Deny access to extension xml files (uncomment out to activate)
#<Files ~ "\.xml$">
#Order allow,deny
#Deny from all
#Satisfy all
#</Files>
## End of deny access to extension xml files
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
# Block out any script trying to modify a _REQUEST variable via URL
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
# Update Your Joomla! Directory (just / for root)
# RewriteBase /
RewriteCond %{REQUEST_URI} !^/index.php
RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
RewriteRule (.*) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
est ce que on pourrait ajouter les ligne de commande sur le meme fichier
<Files ~ "^.(htaccess|htpasswd)$">
deny from all
</Files>
Options Indexes
AuthUserFile localhost
AuthGroupFile /dev/null
AuthName "Please enter your ID and password"
AuthType Basic
require valid-user
order deny,allow
AddType x-mapp-php5 .php
AddHandler x-mapp-php5 .php
puis crée un autre fichier .htpasswd.
# @package Joomla
RewriteEngine On
#<Files ~ "\.xml$">
#Order allow,deny
#Deny from all
#Satisfy all
#</Files>
# RewriteBase /
deny from all
</Files>
Options Indexes
AuthType Basic
require valid-user
order deny,allow
- Sécurité Joomla!
Temps de génération de la page : 0.186 secondes
